Charging indiviual LiFePo4 cells with potentially arbitrary SOC in series is not a good idea. If you try to get the cell with the lowest SOC full, you overcharge the others.
OTOH, the cells of a series pack are charged and discharged together to keep SOC imbalance small, and the pack is usually also equipped with a BMS to re-balance these small differences.
