Author Topic: Scope help  (Read 3750 times)
Offline awwendeTopic starter
Scope help
« on: September 12, 2011, 02:00:21 am »
So the story is, I'm working on a small class D tesla coil/plasma speaker and was working on testing my iphone isolation circuit, which will be using a fiber optic cable. As I was trying to measure an output my screen froze up and displayed an error code:
"Illegal Instruction: 3849F4H"
It's an HP 54600A 100MHz scope (bulky but I love the thing). I've searched google with no luck, and even though it's a copyright 1997 scope I even checked HPs website for technical support (out of desperation). I tried taking it apart to look for a CMOS battery since it displays even after I disconnect and reconnect power, but couldn't find the stupid thing.
Does anyone know what's wrong or how I can fix it?
Offline Psi
Re: Scope help
« Reply #1 on: September 12, 2011, 03:11:29 am »
Dunno,
but here is the service manual with schematics
http://www.home.agilent.com/agilent/redirector.jspx?action=doc&lc=eng&cc=CA&id=1517712&ltype=External%20File
Have you looked over the pcb for anything obvious, like bulging capacitors?
« Last Edit: September 12, 2011, 03:13:03 am by Psi »
Offline w2aew
    • My YouTube Channel
Re: Scope help
« Reply #2 on: September 12, 2011, 03:32:25 am »
Various manuals for the that scope can be found on this page:
http://128.238.9.201/~kurt/manuals/manuals/HP%20Agilent/
I took a brief look at the service manual there, and it didn't initially appear to provide much help with respect to any error codes.  In the Troubleshooting section, it describes a couple of built in self tests, and that if they fail, then replace the system board.  Not very helpful for doing a component level repair.  It does describe a little about checking out various systems, so maybe you'll be able to narrow it down...
FAE for Tektronix
Re: Scope help
« Reply #3 on: September 12, 2011, 04:32:23 am »
Yes, I've looked the board over for obvious problems but it all looks fine from what I can tell.
Offline rf-loop
Re: Scope help
« Reply #4 on: September 12, 2011, 07:11:43 pm »
HP use (Dallas or equivelent ) NVRAM what includes inside Li batteries. You can not measure batt voltage.
I do not know this model NVRAM (I have not anymore these scopes) but I have fixed lot of 5450x series and this model keep cal data in NVRAM. But It can recovery just driving full selfcal routines after first defaulting cal data.
Only what I know about 54600 serie is that it have also NVRAM and typical battery life is (depending many factors) 10 - 20 years. It is HP designed lifetime limit for this product. ;)
If it tell in selfcheck nvram ok, it still do not know battery status.
But first, reset to decfalut (factory cal) and run full selfcal routines.
