Just do not break the power transistors (Usually BeO is used as the insulator between the die and the mounting base), not generally a problem unless you start crushing or grinding the power sand.
The stuff is genuinely nasty, and you really do not want it getting into an open wound or your lungs, but as long as it is contained in the transistors it is not a problem.
Regards, Dan.
