I've been fascinated by the simplicity of the driver circuit based in the
YX8018 in the prominent solar garden lights, they were able to simplify the circuit a lot in a simple boost topology by just running at fixed frequency and using the LED as the output rectifier. I was interested in building my own circuit using a 555 timer driving a small transistor, just to learn more about the topology, but in my research I was not able to find a equation, or at least a simpler explanation between the frequency, input voltage, and inductor value to be able to calculate the output current to the LED. Could someone help me understand how I can calculate the output current given these parameters?
The closer I got to an answer was by reading the
SLVA372C App Note, in the equations section, the inductor ripple current:
Il = (Vin * D) / (f * L)
Plugging the values I tested on my solar light's circuit:
Il = (1.5 * 0.5) / (200000 * 330 * 10^-6)
Il = 0.0107
But when I measured the current to the LED using my DMM I got 6.3mA.
