Author Topic: 555 waveform help  (Read 8997 times)
Offline pinchipTopic starter
555 waveform help
« on: May 31, 2014, 04:45:30 pm »
I am trying to make poor man's waveform generator. Few things I need help with:
1.  How to add sine wave to this model?
2. Triangle wave is not perfect triangle. Is there way to make it start from 0V and end to 5V?
EDIT: I was able to make triangle bigger by adjusting capacitor values to C1 2uF and C2 0.5uF. Now it is starting from 1V and ending to 4V. It takes some time to adjust....
« Last Edit: May 31, 2014, 05:05:08 pm by pinchip »
Offline M0BSW
  • Left this site 2013, they will not delete it ????
Re: 555 waveform help
« Reply #1 on: May 31, 2014, 05:56:12 pm »
Try this one :)
no one would or will tell me how to delete this account
« Reply #2 on: May 31, 2014, 07:28:08 pm »
Thanks!  :-+
This helped to make it work. I need to adjust still some values to get it right
Offline Zero999
  • 0999
« Reply #3 on: May 31, 2014, 10:47:35 pm »
You're better off using a Schmitt trigger and integrator to generate a triangle wave.
If you need a sinewave, add another integrator and an amplifier.
http://www.next.gr/oscillators/varius-circuits/function-generator-l12088.html
EDIT: rather than the TLC271 which is a single op-amp, use the TLC274 quad.
« Last Edit: June 01, 2014, 04:56:47 pm by Hero999 »
« Reply #4 on: June 01, 2014, 04:14:03 pm »
Thx Hero999!
I was doing spice model accordingly and it seems to be real performance test for my computer. Simulation has been running 10 minutes and all four CPU cores near 100% utilization.
Let's see when simulation ends, if it ever ends....
Edit: simulation ended, but result was not as expected. I used LT2178 instead of TLC274 as I could not found those.
« Last Edit: June 01, 2014, 04:28:03 pm by pinchip »
Offline Richard Crowley
  • KJ7YLK
« Reply #5 on: June 01, 2014, 04:37:27 pm »
There is also the piecewise approximation conversion scheme to "round off" triangle-waves to sine-like waveforms...
And schemes using the non-linear IDSVDS transfer characteristic of a P-channel junction FET to shape the triangle waveform of <2% distortion...
Ref: http://www.circuitsproject.com/2014/03/simple-triangle-to-sine-converters.html
Offline Zero999
  • 0999
« Reply #6 on: June 01, 2014, 04:52:04 pm »
Thx Hero999!
The schematic contained an error: the + inputs of some of the op-amps went to 0V, rather than half the supply voltage. I've corrected my schematic.
« Last Edit: June 01, 2014, 05:17:04 pm by Hero999 »
Offline 128er
« Reply #7 on: June 02, 2014, 04:06:35 pm »
build the last shown circuit on my breadboard. Square and triangle works fine. But at the sinus output it's only DC. Changed the 10M resistor in the feedback path of the third opamp stage to 47k and it works, eeehhh, almost. Not a real sine, but better then DC.
Offline Zero999
  • 0999
« Reply #8 on: June 05, 2014, 10:32:56 pm »
Here's another article I've found:
http://sound.westhost.com/articles/sinewave.htm
And this chematice. I can't remember the origional source though.
Offline ludzinc
    • My Misadventures In Engineering
« Reply #9 on: June 06, 2014, 12:07:48 am »
Thx Hero999!
FYI - Your R7 is set to "100mohm" - Spice interprets this as 100 milliohms.  Change to 10MEG and you'll be good.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #10 on: June 06, 2014, 05:42:04 pm »
in the bay you may find IC 8038 it contains a complete generator for sine, square and triangle
greetings
Martin
  • KJ7YLK
« Reply #11 on: June 06, 2014, 10:43:22 pm »
Remember that all of those "filter-based" solutions are good for only one fixed frequency.
If you need a range of frequencies, that is why the waveform-shaping solutions were created.
Offline oldway
« Reply #12 on: June 07, 2014, 09:22:17 am »
Some ideas  :phew:
« Last Edit: June 09, 2014, 03:06:07 pm by oldway »
Offline Zero999
  • 0999
« Reply #13 on: June 07, 2014, 07:23:14 pm »
One way of getting round that is to use a dual ganged pot, so the filter cut-off is also adjusted when the triangle wave generator's frequency is altered.
« Reply #14 on: June 08, 2014, 11:22:48 am »
Good find! I will make correction accordingly. Thank You!
Some ideas  :phew:
WOW, I need some time to study this. Seems to be amazing stuff!  :-+
Offline oldway
« Reply #15 on: June 09, 2014, 02:55:23 pm »
Some explanations to help you:
1) use a symmetrical power supply to generate an ac signal without dc component.
2) choose a CMOS version of 555 as TLC555 or LMC555.
The output of the Cmos version can go near +Vcc and - Vcc and thus generates a square wave.
With a bipolar 555, the duty cycle is not 50% in this schematic.
3) The Cmos 555 generates a square voltage and an approximately triangular voltage which is sufficient for most of the hobby applications.
The maximum usable frequency is about 300kHz.
4) Triangular wave is high Z and must be amplified.
This is done by IC4A (1/2 TL082).
5) sine wave is generated from the triangular wave.
Harmonic distortion is about 2%
6) A very simple output amplifier with 50R output is provided.
Output amplitude and offset are ajustable.
NB: EDIT schematic.
« Last Edit: June 09, 2014, 03:08:25 pm by oldway »
Offline jlmoon
  • If you fail the first time, keep trying!
« Reply #16 on: June 09, 2014, 04:28:24 pm »
Greetings,
If you need a simple function generator.. (poor mans style) have you considered a EXAR  XR-2206?  Now if this is a project (school, etc)  to help with the understanding of integration, filters and the sorts, by all means continue on your current path.  If you need a quick and dirty multi waveform generator the XR chip is a really quick and painless way to move forward.
Regards,
JLM
Recharged Volt-Nut
« Reply #17 on: June 09, 2014, 05:49:51 pm »
Thanks! this clarified a lot functionality
Greetings,
This is project to refresh old man's (me) electronics skills. I chose 555 initially as it is very cheap IC and I happen to have few of those around. EXAR XR-2206 seems offer better quality in all respects. I am glad that you proposed this chip. I will grab it next time I visit my part store. It will be fun to explore it after 555 experiments and maybe I could do some comparison, even we know results beforehand.
Offline oldway
« Reply #18 on: June 09, 2014, 07:12:37 pm »
Do'nt forget the MAX038 ... :-+
It's an absolete IC, expensive and hard to find but with very good performance.
Far better than XR-2206.
« Last Edit: June 09, 2014, 07:23:40 pm by oldway »
Offline robimarko
  • Country: hr
  • High Shool electronics hobbyst
« Reply #19 on: June 09, 2014, 07:48:00 pm »
Its like the king,but i ordered 2 XR2206 for 4.5 USD,and one MAX038 is at least over 10 USD
