Author Topic: MPLAB help PIC12F508  (Read 2423 times)
Offline MuffinsTopic starter
« on: March 17, 2018, 02:37:00 pm »
Hi Guys,
I'm trying to get a blink program to work on MPLAB X with a XC8 compiler, I'm coding in C. My chip is a 12F508.
Coming from programming arduinos, this is quite a steep learning curve and I've found pretty much every tutorial I can find to be a little different. The two primary sources I am using are the closest I can find to the chip I have, the one on youtube:
And the other a Gooligum tutorial. I have had more progress trying to copy the code in the youtube video, it looks like this:
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#include "header.h"
#pragma config OSC = IntRC // Oscillator Selection bits (internal RC oscillator)
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled)
#pragma config CP = OFF // Code Protection bit (Code protection off)
#pragma config MCLRE = ON // GP3/MCLR Pin Function Select bit (GP3/MCLR pin function is MCLR)
#define _XTAL_FREQ 4000000
void main(void) {
    TRISGPIO = 1;
    while(1)
        GPIObits.GP0 = 1;
        __delay_ms(500);
        GPIObits.GP0 = 0;
        __delay_ms(500);
When using this code the LED, which is simply connected via a resistor from source to the pin, lights up but does not turn off.
Gooligum has code that is different, it goes more like this:
void main(void) {
    TRIS = 0b111101;
    for(;;)
        GPIO = 0b000010;
        __delay_ms(500);
        GPIO = 0;
        __delay_ms(500);
The LED does not light up with the Gooligum code.
After I created the project as a main project and added a C file as a source I also added a header file, which it created and I referenced without altering it. I was trying to copy the youtube video.
I seem to have not problem using a pickit 3 to interact with the chip, everything is plugged in the right place and I get no errors. I've been trying for hours to learn my way out of being stuck but I am still stuck. I think the problem with with my code or my IDE settings, I've attached images of my setup, I would greatly appreciate it if you could check it over.
Please help me, haha  :)
Offline Andy Watson
Re: MPLAB help PIC12F508
« Reply #1 on: March 17, 2018, 03:24:09 pm »
 TRISGPIO = 1;   This sets TRISGPIO bit 0 to an input.   1=input, 0 = Output.
This code appears to be written to use GP1 - not GP0.
void main(void) {
    TRIS = 0b111101;
    for(;;)
        GPIO = 0b000010;
        __delay_ms(500);
        GPIO = 0;
        __delay_ms(500);
Yes, breaking into PIC programming can be a very steep curve :)
Offline hugo
« Reply #2 on: March 17, 2018, 04:42:06 pm »
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#include "header.h"
//#define _XTAL_FREQ 4000000
void main() {
TRISGPIO = 0;
    while(1)
        GPIO = 0xff;
        __delay_ms(500);
        GPIO = 0;
        __delay_ms(500);
GP3 pin should be connected to VCC with a 10K resistor (you could also turn it OFF #pragma config MCLRE = OFF) IIRC, you have to decide for the oscillator type: internal or external crystal oscillator, make sure you select the right PIC (PIC12F508) etc.
« Last Edit: March 17, 2018, 04:43:56 pm by hugo »
« Reply #3 on: March 17, 2018, 04:59:25 pm »
Okay, it's working. I would cry right now if I wasn't emotionally defeated.
Tomorrow...more questions.
Thank you.
