Loading [MathJax]/extensions/Safe.js
Author Topic: Displacement current, where is it in electronics?  (Read 1071 times)
Offline lordvader88Topic starter
« on: July 19, 2018, 04:02:35 pm »
Although I have done some stuff with the differential form of Maxwell's eq's and with Clifford algebra, I never did enough to understand what the displacement current is (I just did it for fun on my own, not in class with problems/applications/tests)
So where/when does it show up in EE courses, dealing with resistors, capacitors, inductors, and semi-conductors?
I do have utube, but I'm asking anyways
« Last Edit: July 19, 2018, 04:05:28 pm by lordvader88 »
Offline Wimberleytech
Re: Displacement current, where is it in electronics?
« Reply #1 on: July 19, 2018, 05:28:59 pm »
I watched the video.  It should answer you question very well.
Displacement current is the current that charges a capacitor.
It shows up in EE everywhere capacitors are discussed (which includes semiconductors).  It may be called "charging current" instead of "displacement current."
Offline rfeecs
« Reply #2 on: July 19, 2018, 06:22:59 pm »
Pretty much nowhere.  Although sometimes it is mentioned in dealing with capacitors, it is not needed to understand or describe how a capacitor works.  It might be mentioned in a discussion of how to apply Kirchhoff's law to one plate of a capacitor or something obscure like that.
Where it is mentioned is when you have propagating electromagnetic fields:  in antennas, transmission lines, waveguides.
Maxwell added a term to Ampere's law:
Ampere's law says that a current produces a magnetic field.  The term Maxwell added is the displacement current.  It says that a changing electric field also acts like a current and also produces a magnetic field.
Now, Faraday's law says that a changing magnetic field produces an electric field;  the displacement current addition says that a changing electric field produces a magnetic field.  So the two coupled fields can create an electromagnetic wave that can propagate through space.  This can only be explained by adding the displacement current to Ampere's law.
