Author Topic: 4 Pin Fan Tachometer - Why 2 pulses per revolution?  (Read 3898 times)
Offline bitshiftTopic starter
  • Too much to learn, too little time
« on: July 31, 2015, 07:14:34 am »
Hi all,
I've been playing with a 4 pin PWM controlled fan (Here's a link to a specification for those interested).
The tachometer output signal is defined to output two pulses per revolution of the fan. I understand that there are small magnets attached to either side of the fan. A pulse is generated each time a small magnet passes a hall effect sensor.
Why are there two pulses per revolution and not just one?
TL;DR
In a 4 pin fan why does the tachometer output two pulses per revolution and not just one?
"It’s all fun and games until an innocent opamp gets hurt!" - Dave Jones
Offline dadler
