So the logic would be 4 in series with a DC step-down to 12V.
But does a 3-pack with a DC step-up to 12V would not waste less energy ?
I cannot really figure...
Thanks a lot everybody !
Guillaume
It depend a lot on the board you choose. Some are more efficient than others. General rule I've found is, the higher the input voltage, the better the efficiency -- which is kind of basic physics really.
Personal experience (aka-not expert opinion but what I discovered by messing around) with a dozen or so boost (LM2577/MC34063..) buck (LM2596/XL1509...) at about 300mA-700mA 12V out:
- With buck, you get 90-95% efficiency. When input gets too near output voltage, regulation fails and you have 100% efficiency lost.
- With boost, you get a very wide range of efficiency. The lower the input voltage, and/or, the higher the current draw, the worst it gets. For my use (1x18650 to 12V at 300mA), I get Watt-out at about 60% of Watt-in.
That said, I am chicken (ie: don't want risk), so I stick with 1x(protected)18650 boost. There is no need to balance cell. There is no need to worry about a good cell feeding the destruction of a bad cell should a failure occurs. Awful efficiency, but absolutely no concern of multi-cell issues.
If efficiency is your primary concert, use
6x(protected)18650 and buck it. But you better make sure your cells are balanced and in good shape. That many 18650 is practically a bomb if you abuse it. In my view, even if you have a current-limit with the board, a
hardware-fuse on the cell-side is an absolute must. If there is any excess current, the hardware fuse ensures that the serialization of the 6x18650 is cut even if there is a protection board failure.
Oh, beside protection board failure... there are those cheap cells advertised to have protection board but shown to be without the protection board. The hardware fuse give you some level of comfort at least.
