For the recommended minimum 0.33 uF capacitor at the input to the 78xx series, I usually install a 0.47 uF X7R ceramic (leaded MLCC for through-hole construction), but I have used 0.47 uF polyester (Mylar), which takes up much more space. For the original 78xx, they are prone to oscillation if you omit this part.
