Author Topic: 28VAC plug/socket?  (Read 230 times)
Offline pwnellTopic starter
28VAC plug/socket?
« on: July 18, 2024, 04:29:07 pm »
The 2.5mm DC plug is ubiquitous.  AFAIK they can be  rated for 24V DC and up to about 8A.
What connector can I use - panel mount type - for 24V AC?  I want to connect a 115 - 24V AC transformer's secondary to a small project box, but need a connector that can be panel mounted and will accept 24V AC and at most 100mA.
I tried searching but can only find line voltage AC plugs.
Offline calzap
Re: 28VAC plug/socket?
« Reply #1 on: July 18, 2024, 05:32:50 pm »
Are you looking for a plug or socket or both?  If you go to the Digikey or Mouser website, you’ll find a huge number of styles that can handle 24 VAC and 0.1 A.  Not sure what you mean by ubiquitous 2.5 mm connector.  2.5 mm JST? … not exactly ubiquitous.  2.1 x 5.5 mm connectors are ubiquitous though.  Unless it’s critical or going commercial, I wouldn’t be too concerned about 24 VAC at 0.1 A into connector rated 24 VDC at 8 A.  Most connectors have an AC as well as DC rating … just have to find it.  Line voltage plugs can easily handle 24 VAC, but for safety reasons, do not use standard line voltage plugs for low voltage connections.
Mike
« Reply #2 on: July 18, 2024, 05:45:40 pm »
Offline calzap
« Reply #3 on: July 18, 2024, 06:23:02 pm »
Not sure either what you are doing wrong.  Likely going too low on voltage.  If a connector can handle 120 or 240 V, it can handle a lower voltage.  If you limit search to low voltage only, the selection will be limited.  Also search for plugs and sockets separately, not for pairs.
Mike
Online mariush
« Reply #4 on: July 18, 2024, 06:36:15 pm »
Most barrel jacks will be fine with 24v ... lots of laptop adapters use barrel jacks and output 20v DC ... 24v AC is not a big difference.
Also Digikey has a bunch of barrel jacks rated for 48v AC/DC , here's a link : https://www.digikey.com/short/5pj74hzd
You may want to use a 3 pin keyed connector or maybe a PowerDIN connector , just in case you'll get a transformer with center tap as that would make it easier to get positive and negative voltages.
example : https://www.digikey.com/short/p57j30t3
You could even go to more basics like plain RJ45 connectors ... they do power over ethernet up to 56v so they'll handle 24v AC easily ... Just use a couple pairs for the ac- and ac+
« Reply #5 on: July 18, 2024, 07:03:15 pm »
Thanks!
