Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Parallel USB ESD protection
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Parallel USB ESD protection (Read 200 times)
kristakis
Contributor
Country:
on:
June 28, 2024, 02:19:42 am »
I'm using a SRV05-4 for USB 2.0 ESD protection and it has 4 I/O ports/pins. I only need 2 for the USB port and rather than leaving the other 2 unused, is there any problem with putting them in parallel? As I see it, if something goes wrong and diodes start conducting, won't having an extra path to share the load be helpful?
Here's the datasheet:
https://www.onsemi.com/pdf/datasheet/srv05-4-d.pdf
, I'm using Option 2 in the Applications Information (page 5) with a 10K resistor.
Logged
Things I hate:
1. Forum signatures 2. Irony 3. Lists
wraper
Supporter
Country:
Re: Parallel USB ESD protection
Reply #1 on:
June 28, 2024, 02:31:29 am »
If it's full or low speed USB, there is no problem with parallel connection. However I'd simply use another device like USBLC6-2SC6, SRV05-4 is very expensive for what it is and redundant for the task.
Logged
kristakis
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
