Flushed out my current stash of heavier Resistance wires. 18AWG (0.9 measured so more like 19AWG) I will use Nichrome as it is what I have most of and TempCo doesn't matter at all. The Kanthal is the same diameter but harder to come by so I will save it.
First very crude test on 500mm of it 5V got to 4.4A on my bench supply. With a simple bead contact thermocouple I only hit 130C so more volts and amps need to get to the Acrylic yield point.
Breaking out some more muscle and heavier leads on my messy bench for more testing. Current on the Manson reads high but I will make a better rig and re run it with a calibrated shunt and properly terminated wires. The Croc clips I have with 4mm ends are getting warm at the 8A so not a good indicator.
Voltage is correct as checked on a DMM.
5V 130C
7v 180C
8V @ circa 7A (fudged for the reading) 230C
Looks like for the OP 12V on a 650mm'ish run will pull somewhere in the 250C+ range at 8A'ish so you should be fine (pending some more testing) with the PC supply and 18AWG Nichrome.
Playing with my newish Thermal Camera too the results might be a little questionable due to the surface emissivity of the wire. Still learning
Seems like the calculator earlier is fine for electrical Calculations but off for Thermals too
