Author Topic: 1 MHz crystal options  (Read 176 times)
Offline netdudeukTopic starter
« on: Yesterday at 03:57:18 pm »
Hi
I need a 1 MHz crystal for use with a SFC96364 VDU chip.
The only easy / cheap options seem to be either oscillator modules or ceramic resonators.
I'm thinking that you can't just put the two output pins of a module across the crystal pins on the IC.  Right ?
Would a ceramic resonator be good enough ?
Thanks
Online ledtester
Re: 1 MHz crystal options
« Reply #1 on: Yesterday at 04:41:55 pm »
It might be possible to feed the oscillator module output into one of the crystal pins.
Figure 2 and 3 in this article:
https://www.analog.com/en/resources/technical-articles/replacing-crystals-and-ceramic-resonators-with-silicon-oscillators.html
shows the basic idea. Using an oscillator you just feed the output into one of the crystal pins and leave the other one open.
It might matter which one you feed the signal into.
The following users thanked this post: netdudeuk
Online wasedadoc
« Reply #2 on: Yesterday at 04:46:58 pm »
It certainly will matter. Feed oscillator into pin 1.
« Last Edit: Yesterday at 04:53:08 pm by wasedadoc »
« Reply #3 on: Yesterday at 05:47:51 pm »
Thanks both.  @ledtester, I really appreciate that article you linked to.  I shall read it now.
