It's a completely meaningless specification.
The designer meant something, but wrote down something else. You can only ask the designer.
Ferrite beads are different and they should be specified with part numbers, or at least with the basic stack of parameters like impedance @ 100MHz, DC resistance, and maximum current. Saturation current would be necessary as well but as the manufacturers fail to provide that, designers can't specify it either.
