Indeed. KiCad has a "MountingHole" library, and it has some 100+ pre-defined mounting holes ranging from 2.1mm to 8.4mm and a good portion of them are NPTH (Non Plated Through Hole).
Apart from that, you can set any pad in a footprint to Mechanical, NPTH and/or change it's diameter.
