Author Topic: P-Ch E MOSFET replacement  (Read 661 times)
Offline trondlTopic starter
  • Country: no
« on: September 07, 2023, 10:14:19 am »
Hi!
I'm a noob when it comes to finding transistor equivalents / replacements.
We have a light fixture where the Gobo (effects) card has two shorted transistors:
One NPN ZXTN2010 where I found the exact same and a MOSFET ZXMP6A16.
I only found a ZXMP6A18 available.
The CAN bus communicating circuit is used to control some "smaller" step motors and reading optical sensors with an on board MCU.
Is the ZXMP6A18 just a newer beefier version of ZXMP6A16 and is in this case a drop in replacement?
Datasheets included.
Thanks in advance!
Offline DavidAlfa
Re: P-Ch E MOSFET replacement
« Reply #1 on: September 07, 2023, 11:05:45 am »
It's slighly slower and has higher capacitance, but will probably work just fine.
Do you know what these fets do in the circuit?
  • Country: no
« Reply #2 on: September 07, 2023, 01:01:17 pm »
There is only one of them on this PCB, and the PCB is referred to as "Motor driver low power".
It is controlling 8 step motors through DRV8844 drivers, 8 sensors, CAN bus and 2 blower fans of smaller size.
The board is fed 24V DC, and it has very low resistance from the +24V to the Sink pin.
Should the capacitance cause concern?
Offline DavidAlfa
« Reply #3 on: September 07, 2023, 01:07:15 pm »
Only if switching at very high speeds, which doesn't seem the case.
I'd try them right away.
The following users thanked this post: trondl
Offline CaptDon
  • Country: is
« Reply #4 on: September 07, 2023, 01:10:09 pm »
I noticed you said CAN Bus control. Do the mega expensive pro lights use CAN as opposed to DMX control? I've been involved with some pro gear but it was all DMX. I did locomotive control circuits for years and I hated CANBUS. It never worked well on locomotives. CAN features some data rates of a few MHz but we had trouble with capacitance and cable lengths even at 500KHz. It was unstable in 65 foot cable runs. Ethernet just worked better. Fiber optic at the time suffered degradation from the sulfur in the diesel fuel and wasn't allowed on locomotives.
  • Country: no
« Reply #5 on: September 07, 2023, 01:33:01 pm »
Internal communication between the modules is CAN, DMX is from main MCU to external although Ethernet is in this case also an option.
DMX is the default protocol when it comes to lights and such.
  • Country: no
« Reply #6 on: September 08, 2023, 10:56:21 am »
It worked perfectly!
Thanks a bunch for the guidance.
Only the long run tests in real situations remain.
