Author Topic: 0.01UF 50V ZF - What does ZF mean?  (Read 6277 times)
Offline requimTopic starter
« on: November 02, 2011, 05:18:51 am »
I need to replace a few caps on a receiver and the service manual species the following:
0.01UF 50V ZF
0.1UF 50V ZF
What does the ZF stand for?
Offline Psi
Re: 0.01UF 50V ZF - What does ZF mean?
« Reply #1 on: November 02, 2011, 06:27:44 am »
I think it maybe another way of saying the temperature coefficient of Z5V
There are some graphs here which have Z5V(ZF)      Y5E(YA)    Y5P(YB)    Z5U(ZE)
http://www.docstoc.com/docs/68640250/ARITEC-Ceramic-Capacitor-TABLE-OF-CONTENTS
Also this table seems to back that up. It looks like there are three naming schemes  EIA / JIS / GB
It does seem odd though because Z5V isn't a high spec cap, far from it. It's pretty bad in fact.
So why anyone would label something as needing to be that type of cap is a bit weird.
I'm sure someone will know for sure what it means
« Last Edit: November 02, 2011, 06:35:28 am by Psi »
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« Reply #2 on: November 02, 2011, 06:30:09 am »
It means it should be a 105 oC rated capacitor.
« Last Edit: November 02, 2011, 06:32:01 am by hacklordsniper »
Oh, the joy of sending various electronics to silicon heaven
« Reply #3 on: November 02, 2011, 07:26:02 am »
So if I order a 5% part @ 125C then I should be fine, right?
  • Country: hr
    • HackLordSniper
« Reply #4 on: November 02, 2011, 08:01:05 am »
Yes, even better than manufacturer reccomended specs
alm
  • Guest
« Reply #5 on: November 02, 2011, 01:34:12 pm »
Do you have a source? The PDF version of the document Psi linked to claims 10 to 85°C. Choosing an NP0 cap should work fine, but is probably much larger and more expensive than required for this application if Z5V is called for.
« Reply #6 on: November 02, 2011, 01:52:18 pm »
I was just planning on buying the 3 caps and 2 fusible resistors through digikey.  Total cost is < $5.00. Not a big deal.
  • Country: hr
    • HackLordSniper
« Reply #7 on: November 02, 2011, 02:00:41 pm »
YOu can find this data on Nichicon site
alm
  • Guest
« Reply #8 on: November 02, 2011, 02:12:27 pm »
Does Nichicon even make ceramic caps? How about a link?
  • Country: hr
    • HackLordSniper
« Reply #9 on: November 02, 2011, 03:13:31 pm »
Im not sure how you know does authur means exactly ceramic capacitor, but if you checked their website you could see they dont make only electrolytic capacitors.
Fell free to look http://www.nichicon.co.jp/english/index.html
alm
  • Guest
« Reply #10 on: November 02, 2011, 05:44:32 pm »
Have you seen any 10nF/50V electrolytics (aluminum, tantalum or conductive polymer) lately? It could be film, but this would be indicated as such, and Nichicon doesn't make any film caps with ZF in the name. Part number search for ZF yields no results. Psi's answer looks plausible to me without any proof to the contrary.
  • Country: hr
    • HackLordSniper
« Reply #11 on: November 03, 2011, 05:28:50 am »
Im not going to bother to prove anything to you  :)
