The
MHS35-Show script you use, can install xserver-xorg-input-evdev from
http://mirrors.zju.edu.cn/raspbian/raspbian, which makes myself a bit, uh, suspicious... but really, it is just horribly shoddy work; bad enough to make my eyes bleed.
Anyway, it seems to using the
"standard" fbtft driver, just configuring it differently for specific displays. As you do get a display, the driver is already installed, it's just its configuration that needs fixing. For MHS35, the base device tree overlay (mhs35-overlay.dtb) you should see in your
/boot/overlays/mhs35.dtb0, contains
/dts-v1/;
compatible = "brcm,bcm2835\0brcm,bcm2708\0brcm,bcm2709";
fragment@0 {
target = <0xdeadbeef>;
__overlay__ {
status = "okay";
spidev@0 {
status = "disabled";
spidev@1 {
fragment@1 {
__overlay__ {
tft35a_pins {
brcm,pins = <0x11 0x19 0x18>;
brcm,function = <0x00 0x00 0x00>;
linux,phandle = <0x01>;
phandle = <0x01>;
fragment@2 {
__overlay__ {
#address-cells = <0x01>;
#size-cells = <0x00>;
tft35a@0 {
compatible = "ilitek,ili9486";
reg = <0x00>;
pinctrl-names = "default";
pinctrl-0 = <0x01>;
spi-max-frequency = <0x6dac2c0>;
txbuflen = <0x8000>;
rotate = <0x5a>;
bgr = <0x00>;
fps = <0x1e>;
buswidth = <0x08>;
regwidth = <0x10>;
reset-gpios = <0xdeadbeef 0x19 0x01>;
dc-gpios = <0xdeadbeef 0x18 0x00>;
debug = <0x00>;
init = <0x10000f1 0x36 0x04 0x00 0x3c 0x0f 0x8f 0x10000f2 0x18 0xa3 0x12 0x02 0xb2 0x12 0xff 0x10 0x00 0x10000f8 0x21 0x04 0x10000f9 0x00 0x08 0x1000036 0x08 0x10000b4 0x00 0x10000c1 0x41 0x10000c5 0x00 0x91 0x80 0x00 0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00 0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x100003a 0x55 0x1000011 0x1000036 0x28 0x20000ff 0x1000029>;
linux,phandle = <0x02>;
phandle = <0x02>;
tft35a-ts@1 {
compatible = "ti,ads7846";
reg = <0x01>;
spi-max-frequency = <0x1e8480>;
interrupts = <0x11 0x02>;
interrupt-parent = <0xdeadbeef>;
pendown-gpio = <0xdeadbeef 0x11 0x01>;
ti,x-plate-ohms = [00 3c];
ti,pressure-max = [00 ff];
linux,phandle = <0x03>;
phandle = <0x03>;
__overrides__ {
speed = <0x02 0x7370692d 0x6d61782d 0x66726571 0x75656e63 0x793a3000>;
txbuflen = [00 00 00 02 74 78 62 75 66 6c 65 6e 3a 30 00];
rotate = [00 00 00 02 72 6f 74 61 74 65 3a 30 00];
fps = [00 00 00 02 66 70 73 3a 30 00];
bgr = [00 00 00 02 62 67 72 3a 30 00];
debug = <0x02 0x64656275 0x673a3000>;
swapxy = <0x03 0x74692c73 0x7761702d 0x78793f00>;
__symbols__ {
tft35a_pins = "/fragment@1/__overlay__/tft35a_pins";
tft35a = "/fragment@2/__overlay__/tft35a@0";
tft35a_ts = "/fragment@2/__overlay__/tft35a-ts@1";
__fixups__ {
spi0 = "/fragment@0:target:0\0/fragment@2:target:0";
gpio = "/fragment@1:target:0\0/fragment@2/__overlay__/tft35a@0:reset-gpios:0\0/fragment@2/__overlay__/tft35a@0:dc-gpios:0\0/fragment@2/__overlay__/tft35a-ts@1:interrupt-parent:0\0/fragment@2/__overlay__/tft35a-ts@1:pendown-gpio:0";
__local_fixups__ {
fixup = "/fragment@2/__overlay__/tft35a@0:pinctrl-0:0\0/__overrides__:speed:0\0/__overrides__:txbuflen:0\0/__overrides__:rotate:0\0/__overrides__:fps:0\0/__overrides__:bgr:0\0/__overrides__:debug:0\0/__overrides__:swapxy:0";
which basically describes the display (and touch screen) configuration.
See the line
rotate = <0x5A>;?
<0x5A> = <90>, so it definitely defaults to 90 degrees of rotation.
(Note that if you install
device-tree-compiler package, you can convert .dtb and .dtbo files to sources using
dtc -I dtb -O dts filename source-filename and sources to device tree blobs or overlays using
dtc -I dts -O dtb source-filename filenamebut as your display is a standard ILI9486 one using SPI and configured via device tree, you don't need to.)
The
MHS35-Show script also adds the following lines to your
/boot/config.txt:
hdmi_force_hotplug=1
dtparam=i2c_arm=on
dtparam=spi=on
enable_uart=1
dtoverlay=mhs35:rotate=90
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 480 320 60 6 0 0 0
hdmi_drive=2
where you should take note of the
dtoverlay=mhs35:rotate=90 line.
If you have run
MHS50-Show script more than once after installing Raspbian, you will have multiple copies of the above settings in
/boot/config.txt. Use your favourite editor, for example
nano, to edit it and remove the extra copies:
sudo nano /boot/config.txtIn nano, Ctrl+K deletes the current line, Ctrl+O saves the file, and Ctrl+X exits (as shown at the bottom of the editor window, with ^ being the Linuxy/Unixy abbreviation for the Control key).
After you have done that, you should only need to run one of
sudo sed -i -e 's|^\(dtoverlay=mhs35:rotate\)=.*$|\1=0|g' /boot/config.txt sudo sed -i -e 's|^\(dtoverlay=mhs35:rotate\)=.*$|\1=90|g' /boot/config.txt sudo sed -i -e 's|^\(dtoverlay=mhs35:rotate\)=.*$|\1=180|g' /boot/config.txt sudo sed -i -e 's|^\(dtoverlay=mhs35:rotate\)=.*$|\1=270|g' /boot/config.txtand reboot, to change the rotation of your display. (The above only changes
degrees on the
dtoverlay=mhs35:rotate=degrees line, which you can do equally well using e.g.
sudo nano /boot/config.txt if you prefer. Just remember to reboot afterwards for the change to take effect.)
