Author Topic: (3x-5y)dx + (x+y) dy = 0  (Read 7117 times)
Offline J4e8a16nTopic starter
    • Jean Pierre Daviau
« on: July 30, 2015, 04:18:57 pm »
dy/dx = (5y-3x)/ (x+y)
(5y-3x)/ (x+y) =  5A/ (x+y)   -  3B/ (x+y)
5y-3x =  5A  -  3B
5y-5A =  3x  -  3B
5(y-A) =  3(x-B)
(y-A) * 5/3=  x-B
............... https://www.eevblog.com/forum/Smileys/default/huh.gif
Have a good day,
JPDaviau
Equipment Fluke, PSup..5-30V 3.4A, Owon SDS7102, Victor SGenerator,
Isn't this suppose to be a technical and exact science?
Offline German_EE
Re: (3x-5y)dx + (x+y) dy = 0
« Reply #1 on: July 30, 2015, 06:51:33 pm »
And the point of this math exercise is??
Warren Buffett
« Reply #2 on: July 30, 2015, 10:18:10 pm »
Is to find what type of solution exist for this equation.
This is from Shepley L Ross 4th edition
Introduction to ordinary differential equations.
It is not exact.
I could not found an integrating factor
I have tried v=y/x method
Partial fraction does not seem to work
It does not seem Bernouilli or homogenous.
I am aiming to understand Laplace Transform.
I do it for my pleasure and the pleasure to calculate my circuits.
Maybe it is crasy but I am doing it for tree years now.  I started with trigonometry. It is good for the mind.
Well, that's it.
JPDaviau
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: July 30, 2015, 10:29:14 pm »
wasting your time and mine... in one possibility... y=A, x=B...
Offline onlooker
« Reply #4 on: July 30, 2015, 11:26:19 pm »
A thing having no purpose may still have solutions,
(y-3x)2 = C(y-x)
Offline Christe4nM
« Reply #5 on: July 31, 2015, 10:44:25 am »
It's a differential equation. Write it in the form of dy/dx + y = x. Then solve like a first order linear differential equation.
Edit: tried to rewrite and solve it, but it's a non-linear differential equation. My abilities unfortunately only include linear ones with constant coefficients :-\
« Last Edit: July 31, 2015, 12:15:54 pm by Christe4nM »
Offline Jope
« Reply #6 on: July 31, 2015, 11:09:56 am »
Solution by Wolfram Alpha: (3x-5y)dx + (x+y) dy = 0 .
Offline IanB
« Reply #7 on: August 01, 2015, 05:46:23 pm »
According to Wolfram Alpha that method leads to a solution (i.e. let y(x) = x v(x) and proceed from there). However, the solution does not come out as anything simple.
« Reply #8 on: August 01, 2015, 09:38:05 pm »
dy/dx = (5y-3x / x + y) / x = > -3 + 5y/x  / 1+ y/x
y/x = v   y = vx   ==>d  y /dx = d  vx/dx  ==>v + v' x  ==> v + x*dv/dx
v + x* dv/dx = -3 + 5y/x  / 1+ y/x  ==>
x dv/dx  =  -v^2+4v -3/ 1+v
dx/x  = 1+v / -v^2 +4v -3   dv
from here  complete the square?
 :phew:
I am working at it :o)
JPD
Offline IanB
« Reply #9 on: August 01, 2015, 10:22:11 pm »
Something like this, I believe:
Offline free_electron
    • SiliconValleyGarage
« Reply #10 on: August 01, 2015, 10:43:46 pm »
i use this :
« Reply #11 on: August 01, 2015, 10:44:55 pm »
Laplace Transformations are for beginners. Real men use a Widlar Transformations.
« Reply #12 on: August 01, 2015, 11:12:57 pm »
Yes.
Offline IanB
« Reply #13 on: August 01, 2015, 11:14:33 pm »
 :phew:
JPD
It looks like you got it right up that point. You might notice that ( - v^2 + 4v - 3) can be factorized...
« Reply #14 on: August 01, 2015, 11:18:04 pm »
Thanks for your support :o)
JPD
