Author Topic: factory reset  (Read 12974 times)
rui
  • Guest
factory reset
« on: January 09, 2010, 07:20:16 pm »
Does anyone know how to do a factory reset on a fluke 789. please and thanks.
Offline charliex
  • Car Hacker
Re: factory reset
« Reply #1 on: January 09, 2010, 10:32:10 pm »
I don't, or even heard of it , the manuals are here though  http://www.tequipment.net/Fluke789ProcessMeterSP.html
OLSA
  • Guest
Re: factory reset
« Reply #2 on: January 18, 2010, 10:31:53 am »
I have FVF-SC2 FlukeView Forms software, and there is option for factory reset for DMM Fluke 189. I think that it can do the same job for Fluke 789. You can try with Hyperterminal or better alternatives, but you have to do some investigation to find right command for that option. After that you can to write some script/text file and send it to Fluke789.
But, there are Fluke "short-cut" options for some another Fluke instruments:
Fluke scope meters 123/124:
1. Turn off instrument
2.Press and hold "backlight" key
3.Press and release "on/off" key (instrument will turn on and should hear double beep)
4.Release "backlight" key
end
Fluke 43: device is turn off
1.Press and hold "HOLD/RUN" key
2.Press and hold "ON/OFF" key (should hear double beep)
3.Release "HOLD/RUN" key
end
Fluke 187/189 (problem is "SETUP" key at 789...):
1.Turn on instrument
2.Press "YELLOW"(SET) key and "BACKLIGHT" key (in that order!)
3.Continuously step 2 (should see different text on the screen) until appear "Fcty" on the screen
4.You should see flashing "no"; choose between "yes" or "no" with "BACKLIGHT"(left) key and "BLUE" (right) key
5.Final step is press "YELLOW" (SET) key
Note:If you want to step back, press "YELLOW" key and "%" key (CANCEL option).
« Last Edit: January 18, 2010, 12:36:42 pm by OLSA »
