Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Choosing footprint from library.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Choosing footprint from library. (Read 5120 times)
flodins
Contributor
Country:
on:
June 11, 2011, 01:45:58 am »
Hi
I have a problem with adding items from my own library for which I defined many footprints. On the schematic always lands with a default value, unless I select the Place but it is too much clicking. If you add the built-in library, this problem does not occur I can grab a footprint that interests me and this will be set on the schematic.
Do you know any solution? Something had to switch in my library?
I think that the movie clearly shows all
http://flodins.info/footp.mp4
Logged
thmjpr
Regular Contributor
Country:
Re: Choosing footprint from library.
Reply #1 on:
June 11, 2011, 05:08:54 am »
Weird, don't see that problem in AD9.3. Is this AD10?
All I can think is create a new library project, copy a part over, compile/install and see if it persists.
Logged
flodins
Contributor
Country:
Reply #2 on:
June 11, 2011, 10:12:06 am »
this is AD9
Logged
armandas
Frequent Contributor
Country:
Reply #3 on:
June 11, 2011, 12:01:13 pm »
Did you specify the correct footprint in your schematic library?
Logged
flodins
Contributor
Country:
Reply #4 on:
June 11, 2011, 12:08:41 pm »
yes, you can see that when click place it works, only grabing from my libraries does not work grabing from build in librares is ok
Logged
FreeThinker
Country:
Truth through Thought
Reply #5 on:
June 11, 2011, 05:05:18 pm »
I've never used altium but did you save the footprint with a value attached (ie when you designed it) if so then that would most likely be the problem. If not and altium is assigning a random value (when saved ) then it is indeed strange.
Edit < Just re watched the video and you have got the value item ticked in the parameter list. Does this not display the value?>
Last Edit: June 11, 2011, 05:11:17 pm by FreeThinker
Logged
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
