Ive got a couple of components whereby I need to have custom shapes as pads: E.g. this RF filter:
Regardless of the board, I would always layout this footprint at a minimum so it makes sense to include this in the PCB lib as it reduces effort redrawing. This is also the recommended footprint.
However, I get lots of errors...
I had another footprint for an inductor that id used fill and circles to draw which resulted in the same mess of errors so I redid as rectangular pads and all went away. I presume the problem is unassigned nets with fills and shapes...
What is the proper method of drawing custom shaped pads for components in Altium?
