I have a project to which I've added a PCB document, a schematic document, and a pad/via templates library document:
The pad/via template library is part of the project, as you can see the red arrow above highlights.
There are 2 vias in that library:
And the defined vias appear in the Vias templates panel:
However, when I try to define a PCB Design Rule using the "Template Preferred" Routing Vias, the fields are unpopulated:
There doesn't seem to be a way for me to select the Pad/Via templates library I have already defined and added to the project. What am I missing here? Is there a bug in Altium or am I missing a key step? I've read the online documentation and it leads me to a dead end.
