I've been watching many many videos on youtube and I really like that topic.
So normally during my daily job I'm a software engineer, recently I decided I would like to swing over to electronic engineering (if possible :-). I have access to Altium (through my employer). So I'd like to understand some kind of video grabber and try to make one by myself.
It should be a simple design since it's a one chip solution.
I tried to desolder an existing device (heated up the PCB) just to see the footprint:
http://imageshack.us/photo/my-images/210/qfndesoldered.jpg/So at first I tried to make some kind of PCB library with Altium (Tools -> Component Wizzard -> QFN)
however the dual row layout probably cannot be done with it it seems.
What I noticed through the componentwizard is that there's some solder mask expansion I just wondered that kind of solder mask expansion seems to be so big that the footprint might end up with no solder mask at all.. But from the de-soldered sample I can clearly see a solder mask in between the pins.
As far as I understand the solder mask expansion is the gap between the copper/pad and the solder mask, I don't understand how that should apply to those QFN packages.
I have the package specs I will add them asap.
I wonder how can that one be drawn with Altium designer?
(I'm an absolute beginner please correct me if I'm wrong with something here ^^)
