Author Topic: Altium 20 Move part's pins in schematic  (Read 2476 times)
Offline Fire DogerTopic starter
  • Stefanos
« on: January 31, 2020, 03:09:59 pm »
Hello, is there any way to enable pin moving (with drag n drop) on schematic sheet? I am not sure in which version but there was just a check box (Enable pin editing) and you could just do it... :-//
The only way I found was with coordinates under Properties -> Pins -> Location
It is very handy on making good looking schematics without modifing libs.
Thank you
Offline Cloud
  • Country: si
Re: Altium 20 Move part's pins in schematic
« Reply #1 on: February 06, 2020, 12:05:32 pm »
You click on component and go under properties->pins-> and unlock the lock on bottom left
