Hello!
The the pours on my design are slightly off, its about less than a mil and it won't reasonably effect the physical board. However I would like to at least figure out why this is occurring.
I am observing this behavior with both the clearance around the board edge as well as around traces. Please see the images attached.
Changing the clearance of the board edge clearance to 0mil or turning off the clearance to the board edge pulls the pour straight to the edge with no gap, but with any value there is extra distance that is added to the clearance. Changing the width of the Board Edge has no effect on the clearance of the pour.
I have also tried using the Keep-Out Layer around the board edge with a clearance of 0 mil, but then there is still a small gap between the Keep-Out Layer trace and the pour.
Any help would be greatly appreciated.
Thank you!
