Author Topic: TRansferring only ONE schematic to PCB document  (Read 6330 times)
Offline Kanc1erzTopic starter
  • Being a noob the whole life :)
« on: March 25, 2015, 11:33:12 am »
Hello again, still got basic problems with AD.
I have a PCB Project with two schematic documents and few PCB projects (more than one version :))
When I push D+U - Design -> Update PCB (and choose proper PCB) then all items from ALL schematics are transferred into chosen PCB. But I would like to transfer only 1 schematic to PCB. Where can I find such option?
I tried to search in Google, but nothing interesting found, or just the query was not clear enough to Google.
Thanks in advance.
Offline Vipu
Re: TRansferring only ONE schematic to PCB document
« Reply #1 on: March 27, 2015, 10:57:45 am »
Once I too face same issue and what I did is,I made 2 different project and updated  :( :( :(
Offline hkBattousai
« Reply #2 on: March 27, 2015, 12:29:54 pm »
In this situation, I temporarily remove one schematic from the project. Update the PCB. Then re-add the removed schematic to the project. This is my workaround. I would like to know it it has a proper solution.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: March 27, 2015, 02:40:37 pm »
cant be done.
you are using it wrong.
a 'Design' in altium is 1 board. not  1 page.
you cannot have 2 pcb's in one design.
Offline DerekG
  • Country: nf
« Reply #4 on: March 28, 2015, 02:22:45 am »
cant be done.
Free Electron is correct.
If you have several variants of the pcb (and/or schematic), simply re-save the entire project with a new name.
Then make the variant changes within each project.
This is not only logical but helps you to be quite methodical as well.
I also sat between Elvis & Bigfoot on the UFO.
