I have a bit of an issue I've not encountered before. The Internal Plane clearance doesn't seem to avoid non-round pads properly. I have to enlarge the spacing to ridiculous proportions to clear the pads. I don't recall having this problem previously, but that might be because I almost never use through hole parts.
I tried fixing it in DRE like InPolygon (but InPlane, instead). I mustn't have the correct syntax as I got an error.
I can split the plane around the connectors I don't want affected. But is there a more elegant solution?
My Google-Fu is weak tonight, I guess.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
![](http://i21.photobucket.com/albums/b292/envisionelec/9-20-20136-25-48PM.png)
