Author Topic: v-score and rout paths placement, AD summer 09  (Read 6662 times)
Offline m4l490nTopic starter
« on: August 09, 2011, 02:30:23 pm »
Hi, I'd like to know how can I make a panel in AD S09, specifically, how do I put the v-scoring and routing paths. I've used the "Embedded Board Array/Panelize" but I don't know how to put the v-scoring and the routing paths.
Can you help me with this. THANKS!! :)
Offline thmjpr
Re: v-score and rout paths placement, AD summer 09
« Reply #1 on: August 14, 2011, 09:30:58 am »
Talk to whoever will make the board. It may be easier if they do it.
A separate mechanical layer for routing paths is quite standard. You could use one layer each for v-score and route, or even just a different size trace (with a legend).
But your routing path should already be part of your individual board design?
