Hello all,
I have a PCB project with multiple LED options on the same footprint.
Lets say i have a higher power LED with 4 pads (+ Thermal pad) and another lower power LED with 2 pads can perfectly fit the same footprint with just a bit offset to the side.
One way to get two different pick and place points would be to use MidX MidY on 4 pin LED and RefX RefY lower power LED. But what to do if i have a third option with LED placement?
Is there a way to have multiple P&P point per footprint, or even better have multiple same looking footprints that are easily replaceable with a few clicks but have different P&P points?
Thanks in advance.
