Thanks
I was referring to a schematic component, where you right click, select references and then a list of documents you may have for that component comes up
When I selected one it was coming up as a blank tab named Task.PickATask. Then I got confused with the option to open an external
browser for web urls, thinking there was one for pdfs as well
In this new windows install my data drive where the data sheets reside is now D: where it use to be E: so now all the links in all the libraries and schematics are broken
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I wish there was a way to implement relative paths, that way datasheets could live in a subdir within a main library folder that could be moved and used anywhere
