In Altium Schematic Design, I have a circuit (CER1) in a sheet, and I use a BUS to connect multiple channels. In the parent schematic, I created a sheet symbol from the CER1 sheet. And since I needed to use CER1 twice, I used the REPEAT function to repeat the block, and the entries. Everything is working well except the sheet entry that has a bus connected to it internally. it is giving an error "Bus Range syntax error" How should I repeat this Bus?
