Author Topic: Mystery green dot on schematic  (Read 8889 times)
Offline dnparadiceTopic starter
« on: January 03, 2024, 04:20:35 pm »
Hello,
I have a mystery green dot on my schematic. I can't click it, I cant drag select it, I cant find an object it is associated with. Can anyone identify this mystery dot (see image, arrow points to dot) and let me know what it is?
Thanks
-J
Offline ajb
Re: Mystery green dot on schematic
« Reply #1 on: January 04, 2024, 09:34:34 pm »
Does it persist across opening/closing altium?  Recompiling the project?
If you can't get rid of it any other way, you might move all of the components to a new schematic file.  Doing that via cut/paste will generally fuck up your component links, but there's a way to avoid that.  Edit » Refactor » Move Selected Subcircuit to Different Sheet: https://www.altium.com/documentation/altium-designer/design-refactoring#!moving-selected-sub-circuitry-to-a-different-sheet
« Reply #2 on: January 05, 2024, 12:12:40 am »
Yes to both. I will try a new schematic, thanks for the tip.
-J
Offline mengfei
  • Country: ph
« Reply #3 on: January 12, 2024, 03:40:08 am »
if you select ALL can it be moved?
« Reply #4 on: March 07, 2024, 02:29:13 pm »
No I cant find a way to select it. I resigned myself to ignoring it.
Offline tszaboo
« Reply #5 on: March 07, 2024, 02:34:29 pm »
Update video card drivers. Get an nVidia card if you don't have one. That's what I see visual bugs with most of the time.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: March 08, 2024, 06:19:45 am »
Try deleting objects until it goes away, narrow it down until you find the culprit.  If still there, try saving the template separately, edit that and see if it's in that way.
There are also ways to select things with queries that can't be selected by double/clicking.
Seven Transistor Labs, LLC
Online voltsandjolts
« Reply #7 on: March 08, 2024, 08:03:50 am »
Welcome to Altium.
Place something over it to hide it :P
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #8 on: March 11, 2024, 12:30:38 pm »
You can try selecting each item in the SCH List panel and see if it is in there. It almost looks like the "Show Graph" functionality that is available in the Navigator panel.
“They Don’t Think It Be Like It Is, But It Do”
Offline doklevise
  • Country: cs
« Reply #9 on: March 19, 2024, 10:44:48 pm »
Have you tried Shift+c ?
Offline mengfei
  • Country: ph
« Reply #10 on: March 25, 2024, 02:00:27 am »
open a new blank SCH Template copy your design & paste it
- if the green dot follows it could be attached to one of the components
- if that happens, try copying by sections until you narrow it down
i'm slightly OCpd  :-DD
