Author Topic: Opening component datatsheets in external acrobat (Altium)  (Read 4616 times)
Offline AlfBazTopic starter
Does anyone know what setting to change to have altium open a datasheet in adobe acrobat?
I just did a complete OS re-install and although I saved my prefs, loading them didn't fix it.
At the moment its just opening a blank tab.
Offline David_AVD
Re: Opening component datatsheets in external acrobat (Altium)
« Reply #1 on: May 30, 2013, 10:55:19 pm »
I just added a pdf to an Altium project and it opens up in Acrobat Reader correctly.   I've not changed any settings relating to that as far as I know.  :-//
« Reply #2 on: May 31, 2013, 08:37:18 am »
Thanks
I was referring to a schematic component, where you right click, select references and then a list of documents you may have for that component comes up
When I selected one it was coming up as a blank tab named Task.PickATask. Then I got confused with the option to open an external browser for web urls, thinking there was one for pdfs as well
In this new windows install my data drive where the data sheets reside is now D: where it use to be E: so now all the links in all the libraries and schematics are broken :palm:
I wish there was a way to implement relative paths, that way datasheets could live in a subdir within a main library folder that could be moved and used anywhere
