Author Topic: Scaling 3d model when making a component?  (Read 6311 times)
Offline reagleTopic starter
    • KuzyaTech
« on: May 28, 2013, 04:32:19 pm »
I've been trying to add a 3D model to a connecto . It's a Molex part and the Step file is supplied by them.  All goes well, but the part is actually appearing to scale incorrectly- it's too small. Is there a way in Altium to apply scaling factor when importing a model?
Offline 8086
    • Circuitology - Electronics Assembly
Re: Scaling 3d model when making a component?
« Reply #1 on: May 28, 2013, 04:37:08 pm »
That's odd. Have you tried contacting molex about it? Sure you have the right part?
    • KuzyaTech
« Reply #2 on: May 28, 2013, 04:39:29 pm »
Part number is the same and it looks right, just small ;)
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: May 28, 2013, 05:54:30 pm »
that's weird.
are you sure you have a correct STEP file (AP214) ?
havent' seen that. scaling can;t be done ( it defeats the purpose of step files... they are supposed to be 1:1 scale)
    • KuzyaTech
« Reply #4 on: May 28, 2013, 06:01:30 pm »
I wasn't sure if Step model has units or scale.
The file came from http://www.molex.com/elqNow/elqRedir.htm?ref=http://www.molex.com/pdm_docs/stp/54819-0519_stp.zip
Offline Rufus
« Reply #5 on: May 28, 2013, 07:12:30 pm »
The model looks OK to me and a few measurements I made match dimensions in the 2D PDF drawing on the same page.
    • KuzyaTech
« Reply #6 on: May 28, 2013, 07:26:59 pm »
Never mind. I am totally being stupid. My drawing and the new model were 90 degrees from each other. See picture  and thanks for the help! :palm:
« Last Edit: May 28, 2013, 07:33:46 pm by reagle »
