Author Topic: Multiple P&P points per footprint  (Read 2728 times)
Offline WR3Topic starter
« on: May 28, 2013, 08:19:07 pm »
Hello all,
I have a PCB project with multiple LED options on the same footprint.
Lets say i have a higher power LED with 4 pads (+ Thermal pad) and another lower power LED with 2 pads can perfectly fit the same footprint with just a bit offset to the side.
One way to get two different pick and place points would be to use MidX MidY on 4 pin LED and RefX RefY lower power LED. But what to do if i have a third option with LED placement?
Is there a way to have multiple P&P point per footprint, or even better have multiple same looking footprints that are easily replaceable with a few clicks but have different P&P points?
Thanks in advance.
Offline Niklas
Re: Multiple P&P points per footprint
« Reply #1 on: May 29, 2013, 10:27:49 am »
I haven't used it myself yet, but this sounds like "Assembly variants"
http://wiki.altium.com/display/ADOH/Managing+Design+Variation+with+Variants
Place all 3 components and control which one to populate in each variant. Each variant will have its own pick and place file.
« Reply #2 on: May 29, 2013, 08:11:44 pm »
Thank You
I knew about assembly variants but didn't know you can change the component case and placement too. I will have to look this assembly variants in more details then. Hope i can find what i need between all this Altium documentation and tutorials :-)
But if I must place all 3 components in pcb one on top of another and then select between them that seems like a lot of extra work... but i have to try it out first.
