Is there any method of running a batch file or other script after an export is complete? I'm not finding a way to modify the output job enough to do exactly what I want.
An example of this is a script for each type of board fab house. OSH Park wants NC Drill as XLN. It is .TXT. I can't find a way to copy the .TXT to .XLN or renaming to that without manually doing it. It would be cool to be able to copy only the relevant files to a directory, so all I have to do I zip up the directory after I check the gerbers.
