Author Topic: How to get smooth edges in Altium Ground Pours  (Read 381 times)
Offline Arsh ahmadTopic starter
  • Country: in
« on: June 06, 2024, 10:40:56 am »
I want to smooth out the attached marked areas of polygon ground pours in Altium Designer. In software like Allegro there is an option called smooth pours that removes all the sharp corners in pours.
I don't see any such option in altium deisgner, please help me in finding a easier way.
Online T3sl4co1l
    • Seven Transistor Labs
Re: How to get smooth edges in Altium Ground Pours
« Reply #1 on: June 06, 2024, 02:45:47 pm »
I avoid square pads for this reason.
If nothing else, you can blanket set all square pads to rounded and set the corner radius small like 1%, but it'll look better with more like 20%.
Seven Transistor Labs, LLC
Offline tszaboo
« Reply #2 on: June 06, 2024, 03:31:54 pm »
In the properties of the polygon pour, you set up Arc approximation to a smaller value.
I also suggest changing the "Remove necks" to maybe 0.4-0.5mm then it doesn't pour below small SMD components.
Offline plazma
    • Homepage
« Reply #3 on: June 08, 2024, 02:23:40 pm »
Decrease arc approximation of the polygon.
Even better... make the polygon pour hatched with 0.2mm track width and 0mm grid size. Decrease the "Min prim Lenth to 0.01mm. "Surround pads with" set to Arcs.
