Hi guys,
I am just starting to learn to use Altium Designer 15. I'm coming from several years of experiance with EAGLE, and have found this forum to be quite a supporting place for AD issues. So I hope you guys can give me a bit of support on my early steps, so that I can soon give it back
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Currently I try to figure out how I use components that already exist, and I'm using this USB connector from the Altium Vault. However, when i compile the project (using Project->Compile PCB Project ...) I get this warning with the message "Component J2 48204-0001: Can't perform revision state validation: Altium Content Vault doesn't support revision state validation".
Doesn this mean:
- I shouldn't use the Altium Content Vault components?
- I shouldn't use revision state validation? (how would I disable that?)
- I have done something wrong, like configured something incorrectly?
I'd be glad about some hints on this!
Cheers
Janos
