Hello all,
I have a top and bottom solder polygon pour (in purple) with a board cutout region inside it (the board cutout region has been made by converting some primitives into a board cutout).
I have tried all possible clearance rules related to polygons, regions, and board outline (as seen in the attached images) but couldn't remove the solder on the cutout edges (3d view image).
the solder polygon pour clearance rules work fine with board edges but not cutouts!
Any solution, please?
Thanks,
