Author Topic: Make instance of a sheet to use in multiple projects?  (Read 1205 times)
Offline hal9001Topic starter
« on: July 08, 2021, 11:17:30 am »
I have a schematic with a circuit that will be used in multiple projects.
Instead of copying the circuit from this sheet every time for every project that uses it, is there a way to use an instance of the sheet and have the annotation from one project not break the annotation from another project?
Cheers!
