Say I am creating a new part and need to define things like mechanical outline, courtyard, assembly layers etc. Depending on the library I look at, those end up on different mechanical layers. One library would use layer 20 for courtyard, while Altium's own IPC wizard would use layer 15. Is there a standard somewhere defining what they should be or is this all up the user/librarian?
