Author Topic: Create a routing desing rule for connection  (Read 883 times)
Offline DartherickTopic starter
  • Country: do
« on: November 09, 2022, 01:13:11 pm »
Hello Everyone,
I would like to create a routing design rule (width) for a connection in my PCB in altium designer 22. Does anybody know how to do it?
https://www.altium.com/documentation/altium-designer/pcb-connection?version=21
Regards,
Offline ajb
Re: Create a routing desing rule for connection
« Reply #1 on: November 09, 2022, 04:00:12 pm »
There are many ways to do this depending on what exactly you want to do.  Terms you should look for in the documentation are in bold below.
From the PCB Editor, select Design > Rules to edit the existing rules or add new ones.  If you want to set a minimum (and/or maximum) routing width, you can create a single routing width rule (or edit the one that's already there) that will apply to the entire PCB.   As you'll see, there are many categories and types of rules (your PCB file may not have all types defined), and you'll want to become familiar with many of them to get the most out of Altium.
If you want to apply a rule to a specific net, you can create a routing width rule that targets that specific net name.  If you want to apply a rule to a whole set of nets, you can define a net class to contain those nets, and create a rule targeting that net class.  Net (and other) classes can be created and edited in the Object Class Explorer, but it's usually better to use directive objects in the schematic to assign nets to their net class (you can also use directives to directly apply rules to the net from the schematic, although this is harder to maintain).  If you want to apply a rule to a specific segment of a net, for example from one specific pin to another within the net, then you can define an xSignal in the PCB pane and create a rule targeting that xSignal or the xSignal Class (xSignals are generally meant for high speed routing, but you could use them for other things).  You can do more complex targeting of rules by constructing a query that defines what objects the rule should affect.  Altium's query language is clunky and inconsistent, so for complex applications you may want to use the PCB Filter pane to develop a query semi-interactively and then copy and paste it into the rule.  Note that if an object is covered by more than one rule of a given type (for example, more than one routing width rule) you will need to use the Priorities button in the Rules Editor to ensure the rules are applied in the correct order.
Note that most rules can be targeted at different objects using these or similar methods, although different things will make sense for different rules.  Understanding the query system can make for very powerful rulesets, although there are some limitations and weird corner cases.  Rules can be imported and exported, or saved as part of a PCB template file for future use so you don't have to go through all of this from scratch on every project.
Design rules can get very complicated, especially with complex queries involved, and Altium is far from the most consistent or reliable piece of software in the world, so if you need more specific help with a challenging rule situation, please let us know what you're trying to do.
« Last Edit: November 09, 2022, 04:04:58 pm by ajb »
The following users thanked this post: thm_w, Dartherick
