I'm using Altium designer for a board where some traces need controlled impedance, for example Ethernet trace. I'm not very good with this but from what I can tell, differential ethernet traces should be routed as coupled microstrip lines which has reduced impedance when compared to a normal single ended trace. The problem is that Altium does not seem to take this into account?
Also, I can see no option for doing things like Co-Planar Wave Guides either. Am I missing something?
