Hi everyone,
since I am progressing in my learning of altium designer I noticed that I often use the same circuit multiple times in different projects, for example the standard "Connector + rectifier + cap + 7805" thing. Now I remember that I heard somewhere of the possibility to group multiple objects and safe those as a seperate building block which can be used over and over again in any new design without the need to place every component and rout them at the PCB again. Sadly, even with some time googling and searching on altiums tech docs I couldn't find what I was looking for.
Am I a mistaken and this feature doesn't exist, or am I just not finding the information I need? And if so, could you point me to it?
Thanks in advice!
