Hello,
I have OLD Altium 14.1.5 and my experience printing error when generates pdf.
The problem is that it creates lines that go to the infinite, if you delete the component from the PCB they disappear but this is not a good solution.
I leave you an example.
I change the Adobe pdf version and try in other computer and the problem is the same.
