Author Topic: LGA Footprint - Component Wizard  (Read 8793 times)
Offline DavidTopic starter
« on: May 16, 2013, 07:51:08 pm »
Hi all,
I am just starting out with Altium (not PCB design) and I am fairly impressed so far. I am now attempting to create my own footprint. I require an LGA package and I am attempting to use the component wizard but there is no LGA option. I am best selecting an LCC and modifying or just creating the footprint from scratch? Also, am I correct in selecting New > PCB Library to make the footprint?
P.S. Anyone have a nice keyboard shortcut A4 sheet I could print out and place on my desk?  ::)
(United Kingdom)
Offline Fox
  • Electronics Engineer
Re: LGA Footprint - Component Wizard
« Reply #1 on: May 16, 2013, 08:12:40 pm »
you could try use one the BGA variants and modify them for you needs.
To create a footprint you can create a new library or add one to an existing library.
A closed Switch should have zero Ohms or less!
Offline poorchava
  • Troll Cave Electronics!
« Reply #2 on: May 17, 2013, 07:45:35 am »
on a single A4 sheet that would have to be with a REALLY tiny font...
« Reply #3 on: May 17, 2013, 07:05:01 pm »
I suspected that might be the case!
On a separate note, the dimensions for this LGA footprint are confusing me. The pad width is T2, and length T1, however there appears to be a third dimension T3. Now this is stated as T3x4 so I can only assume this is for the four corner pads?
Datasheet: http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00254111.pdf
(United Kingdom)
« Reply #4 on: May 17, 2013, 07:06:45 pm »
On second thoughts, I'm fairly certain it is the corner pads...
(United Kingdom)
