Author Topic: Signal Selection Via Componet Placement  (Read 2680 times)
Offline embeddedbobTopic starter
« on: May 15, 2013, 09:23:45 am »
I have an output that is selected at manufacture by placing a component on the correct pad. As its RF I want a single pad entry and then depending on the component, depends on which route the signal takes. See here:
Whats the best way in Altium to accomplish this? Is it to draw a three headed schematic/PCB footprint ? or overlay lap them and ignore/turn of error check due to overlap?
