There is nothing too special about this edge, you just need to place a ground plane, then draw lines or polygons on your soldermask layer to uncover the gold plated PCB beneath.
Some boards will have edge gold plating as well, but I don't think this has it. You have to tell the PCB manufacturer if you want that done.
I'll ask to move this to the regular PCB forum as its not Altium.
